There is two methods of removing the back of this style of watch. Look closely at the back of the watch. If it is completely smooth there will be a notch or groove where you can gently, but firmly, lever the back cover off. Use a small screwdriver or a thin flat edged tool, NOT a knife! Refitting is a firm, constant pressure over the whole of the back cover.
If there are regular notches, grooves or holes or around the edge of the cover it is a 'screw off' cover. You may need a specialist tool to remove these back plates.
Depending on how much the watch is worth and the cost of the battery it is probably just as easy to get a watch repair shop to do it for you.
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
SOURCE: Relic Wet watch
Like many other watches, the Relic Wet's battery can't be changed by the owner. It requires a Jeweler's wrench. Said wrench has prongs that fit into the 6 indentations on the back of the watch. The wrench is than used to unscrew the back plate, exposing the battery. Any reputable jewelry store will have one.
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case
opener claws. For this yoy need case opener with interchangeable claws.
You can buy it on ebay for approx. £7.00.
If the casebask is
snap-on, then there shouldn't be any grooves, just small opening (lip)
between the caseback and case. This is exact point where the
watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
