SOURCE: Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
SOURCE: Error 2
The manual that came with my coffee maker (same Kitchen Aide & same ERR2) says if pushing the on/off button a few times to reset it doesn't fix it, it's probably an electrical problem. It comes wirh only a 1 year warranty (mine's about 2 years old). If your maker is less than 1 year old you can call 1-800-541-6390 (M-F 8am-8pm, Sat 10am-5pm Eastern time) for a replacement. Otherwise, you just have to get a new coffee maker. I found no instructions to send it in to get it repaired.
SOURCE: My top loading machine always stops on Rinse
Did you find a solution? Mine is doing the exact same thing : ( Thanks.
SOURCE: my ifb washing machine digital
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
