We want to know how to clean the filter for our dyson air & heat machine Product #SSID
It is one year old and your commercial on the tv says you replace the filters for free
  • 1,234 Answers
Not sure but hope this helps.....
https://www.youtube.com/watch?v=fJI5S7qmMXY
you can vacuum off the filter till you have a replacement.
Posted on Dec 22, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Dyson DC07
http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
Posted on Mar 19, 2008
Anonymous
  • 12 Answers
SOURCE: Air Filter Cleaning error message
There are indeed 2 air filters on the light engine. To clean these, it is necessary to open up the television's back lower panel, remove an electrical component, then slide out the projection unit (you must be very careful - this is over $600 to replace if you break it). The air filters are pretty easy to clean...I used gentle strokes from a soft bristle hobby paintbrush and blowing (I wouldn't recommend using a can of compressed air for this...these filters are somewhat fragile). Dust out the rest of the unit pretty good (use EXTREME caution when doing this). Then put everything back together, and then you have to go through the re-alignment procedure. You can obtain the technical service manual on the Internet...sorry, but I can't help you find it...I am not sure about the legal/copyright ramifications of distributing the manual w/o Panasonic's permission...but its out there...Google is your friend. I would NOT attempt this repair without this manual...it contains crucial diagrams, and "gotcha" warnings (like what order to tighten screws for example). This isn't a hard repair if you just take the time to prepare, move slowly and methodically, and don't be in a rush. Good Luck!
Posted on Sep 22, 2008
Anonymous
  • 3 Answers
SOURCE: Panasonic 50" LCD TV PT-50LC13
I did the following 'press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds (they say over 5 seconds in the manual)"
Will in the service screen I selected the number of hours of the lamp with the down arrows and the action buttons. Then I simply pressed and held the "down volume button" on the remote until the number of hours was 0. Then I turned the TV off, then back on and the message was gone. This worked for me.
Posted on Nov 13, 2008
jose martinez
  • 159 Answers
SOURCE: How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Posted on Apr 18, 2009
barceloco
  • 19 Answers
SOURCE: how do i clean the air filter in my pt-50lc14 tv ?...
hi here u solution, no easy, but u can try,good look :)http://schematicsforum.com/schematics//TV/Panasonic/PT-50LC14.pdf
Posted on May 27, 2010
My dyson d14 animal keeps cutting in and out. When it's on, the hole above where the filter is, keeps making a loud suction noise and it won't clean up hair and dirt.
Vacuum Cleaners require AIr-Flow. Your machine is not getting any air-flow. The noise you hear is a valve opening up to prevent your machine from overheating and burning out the motor.
You probably have an obstruction somewhere in the machine. Dysons are kind of known for that in the vacuum cleaner world.
Check all air channels and clean them out. If that fixes the problem you still might have issues that caused it to clog up.
I posted the part second because it takes 24 hours to complete it.
Be sure you wash your Washable Pre-filter. It needs to dry for 24 hours. Never put it back in the machine wet.
Once it is completely dry reinstall the pre-filter and your machine should be back to normal operating functions.
Let me know f this helps.
Dec 31, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson animal died while vacuuming and will not turn on now?
I'm sorry to hear you're having difficulties with your DC17. Your machine is equipped with a safety device which shuts the cleaner down to prevent overheating - this is often due to a blockage, or because the filter needs a wash.
The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
In normal use, the filter should be washed at least once every 3-6 months. I note you've already cleaned the filter, but you might want to watch the video below to check you've done so as recommended. Use cold water without detergent, and allow at least 24 hours for the filter to dry completely before replacing it.
This should resolve the issue, but for any further assistance or advice, please call us free on 1-866-693-9766, or email us at askdysonUS@dyson.com
Best wishes,
Jack
Dyson Online Customer Support
Jan 16, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a 5 year old Dyson DC07 animal vacuum cleaner. I'm having problems with the vacuum strength when cleaning the carpet but not when using an acessory to clean the stairway carpet. Any possible
Hi Ronald,
I'm sorry to hear you're having difficulties with your DC07. If your machine picks up well through the hose, but not through the cleaner head, it's likely that you have a blockage in the cleaner head.
The easiest way to locate and remove any obstructions is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-ANIMAL_US
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve your issue, but if you have any further questions, please get in touch with us directly on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Nov 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
It is not picking up from the carpet--the exhaust air is coming out the bottom back and not from the top handle--I was not the last to use the vacuum--I think the housekeeper used the handle hose and the...
Sorry to hear your DC28 Animal is not picking up. To check everything is correct with your machine, please ensure the filters are clean, and the cleaner is free of blockages. This guide from the Support section of our website shows the easiest way to do this:
http://www.dyson.com/support/help.asp?article=1456&product=DC28-ANIMAL
Please note the motor exhaust, where filtered air is returned to the room, is located beneath the clear bin. Exhaust air will never come out of the top of the handle.
If you've checked the machine for obstructions and are still having problems with the performance, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com , so we can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My dc01 upright does not pick up dirt as well as when I first used it (new) after many years of faithful service. I regularly disassemble barrel and wash it and clean turbine head and clean filters. Does...
Sorry to hear of your problem with your DC01. Although it sounds as if you've already checked your machine over quite thoroughly, you might find it helpful to visit the Support section of our website to ensure you've covered everything:
http://www.dyson.co.uk/support/help.asp?article=1919&product=DC01-SY-STD
Unfortunately, we are no longer able to supply spare parts, or carry out service or repairs for DC01 and DC02 machines.
However, as the owner of a DC01, you can receive £100 off selected Dyson Ball™ vacuum cleaners, or £70 off selected other Dyson vacuums. We'll also collect and recycle your old machine.
If you have any questions about this offer or would like to discuss this further, please call 0800 954 0153.
Kind regards,
Jack
Jul 21, 2011 | Dyson DC08 Hepa Allergy Bagless Canister...
Is there any health issues with using a Living Air Filter in your home? A couple of years ago, I heard there was legislation being proposed to ban their use in California.
California Air Resources Board was paid to ban any non-commercial Ozone-producing machines from being shipped into the state. Volarra, didn't want to spend the money to DEMAND they produce a list of injured parties, ALWAYS a part of any ban on a product. When I called them they said they knew of no injuries or medical lawsuits. I've never heard of any...after 9 years. Green Environmental Technologies installs the Space-Certified part into Hospital Surgical rooms, the OLD ozone technology got rid of my 2 boys teen-room odors and they stopped using their inhalers. Went from 4 per month for 15 years for the both of them, to 4 per year. GET also went to the Atlantis Casino and purified their KENO room with a single OLD technology commercial unit. GET-GreenTech.com They've been commercial certified, mold certified, have a PhD on staff, with partners across the country. This technology is good enough to fight a toxic chemical spill, so YES there's a chance that you could overuse it. But like the water tap, you should learn the symptoms of it being too high. Headaches, pool bleachy smell, sore throat in the morning that goes away pretty fast. These machines are supposed to be on as LOW as possible!
May 11, 2011 | Ecoquest Fresh Air Air Purifier
Can I clean the air filters or have to replace them and if so how often? I would also like to know where I can purchase new filters if necessary. Thank you!
Hi Thank you for contacting FixYa. We love to fix things.
You havent mentioned what make of Vacuum you are using.
Assuming this is a Dyson then yes you can wash the filters, let them dry then re-use them. You can wash the sponge type filters using fairly liquid and running under the tap and squeezing out the dirt just like you would with a normal sponge.
The Hepa Filters can be cleaned using a power washer or by placing them in a pillow case and puting them in the washing machine on a low heat low cycle. Ideally you should not need to replace the Hepa filters but i would recommend you do so after 1 year.
Oct 26, 2010 | Vacuums
Vacuum is about 4 years old does not pick up well
Have you ever replaced the belt? That is most likely the reason that it is not picking up like it used to. You are actually supposed to change the belt yearly. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belts and Manual
Dec 31, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 motor overheats
the motor brushes are worn down and can be expensive to get someone to fit them for you so i think its time for a new cleaner
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
