The cap is to cover hole opposite the inflating pump.
SOURCE: what is an indoor solution to finding the leak in
Two ways, one is to move around it slowly using your cheek (face that is). It is sensitive and will pick up the leak easily, and then just mark it with a marker. The other, although a little messy, but extremely effective is to use your bath tub. Best of luck.
SOURCE: Help! I converted my Baby's Dream Generation Next
Did you get an answer to your question? I have the same problem.
SOURCE: My air mattress won't stay inflated. What's wrong?
If its just a small leak of air once in a while, don't worry. However, if you notice that the air is deflating considerably throughout the night you will need to check for holes.
SOURCE: I have a SeaHawk 340 that is missing the cap for
Too late with this reply, but hope it helps someone else like us. I had the same problem, then discovered the boat manual and found the cap is called a Boston valve; in this case 2cm (diameter). I cannibalised a smaller boat of ours for one (valve the same size), and you may get one cheaply by doing the same from a cheap boat at a car boot sale. Otherwise search eBay or Amazon for "Boston valve" or "Boston screw"; not cheap, but still a lot cheaper than a new boat.
