Televison & Video Logo
Gerard Okeeffe Posted on Dec 19, 2018
My hannspree tv does it have an outgoing audio to plug into and haw do I get it
Hannspree 28" tv video shuts off after on for a few minutes
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
1helpful
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
1helpful
I have a 42in hannspree that i am trying to hook my surround sound. What do I do?
Run an optical cable from the back of the TV to the input on you audio/video receiver amplifier, then access the A/V receiver's menu and navigate to optical inputs, assign the one you connect the cable to in the previous step, to TV or Sat function (the input or source on your remote), verify it and you are done.
If no optical output on the back of the TV, then use the RCA audio output, and just connect it to any audio input on the back of the A/V receiver, and use that specific input as a source when listening to the surround.
HDalacarte.com guy, audio/video/computer technician for over 30 years
Can you hook up a digital camera to a 32 inch tv and if you can, how
try one of these cables
ebay search
Mini USB to 3 RCA Phono Plug Audio Leadlegz720.jpg Cable
I have a Hannspree 25" flat panel LCD and I can't get the volume to work.
Most monitors/TV come with a remote. Although the remote offers full funtionality, there are usually basic controls on the set itself. Usually these buttons are present; Menu, Volume up/down, channel up/down, input, and the ever popular ON/OFF.
Depending on the type of connection you have going to your display, you may additionally need audio.
HDMI: No separate audio needed.
Component (Red, Blue, Green) Audio L/R needed.
S-Video (Round 5 pin cable) Audio L/R needed
Composite (Yellow RCA) Audio needed
However you did mention the VOLUME did not work, if it is too high, a setting in the TV's menu to select a different output. either STATIC (ONE LEVEL, the you can not adjust), or DYNAMIC, one that you can adjust.
Check the Menu options ofr your audio.
Good luck and don't forget to vote!!!!
35helpful
2answers
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
1helpful
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Can a macbook pro work with a hannspree 28" LCD monitor?
I cant see why not, On you TV you have incomming port called HDMI, on your mac you have an outgoing port called MiniDislay for DVI.
You can use that port whit an adapter to make it to a real DVI, the you need another adapter to reform the DVI to HDMI. It can be done, its a little bit tricky, but it can be done.
here is the spec on your mac
http://www.apple.com/macbookpro/specs.html
And here are the spec for yor tv
http://shopper.cnet.com/lcd-monitors/hannspree-hf289hjb-flat-panel/4014-3174_9-32915918.html#info-5
Good luck to you
If you find my answer helpfull, dont forget to vote
Hannspree 15'' inch - NO audio problem.
Any chance you could have turned off the internal speakers in the audio menu? Or muted the Tv inadvertently??
Bill
Top Hannspree Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
