Freezer door pops open a crack whwnever the main door is shut. Freezer remain a bit open leading to defrosting around the door of freezer compartment and loss of energy. Also freezer door does not swing shut on own from half-way even after adjusting levelling whereas main door swing shut without any issue.
There's a little black metal tab that has no real function, but it'lll make your refrigerator and freezer open at the same time.. and not allow it to close well. I had a tough time gettin the screws out..I used a screw extractor. Ask me (****) if you need
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Hi if this is happening on and off, where the frost goes away and comes back, your freezer door or one of the fridge doors is not getting shut all the way, this is very common on the french door models, if this model has a door alarm marke sure its on, sometimes they are cracked so slightly that the door alarm doesnt pick it up, so you just have to make sure that all doors are shut tightly should take care of your problem.
I also own a model # TT18DKXRQ01 Estate refrigerator and my freezer door pops open when I close the refrigerator. As you stated, this is caused by the magnet in the freezer gasket not being strong enough to hold. As far as I know, they do not make a stronger freezer gasket but even if they did, it would probably be too costly considering that a standard gasket replacement costs $80.
My solution was to install an adhesive child safety lock on the top of the freezer near the door handle. I purchased the 'Safety 1st Lock Release Fridge Latch' model # HS038 from my local Walmart store for around $5.
You may find this solution to be slightly inconvenient at first but you will get used to it. It sure beats losing food because the freezer door was accidently popped open.
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door...If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well. Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door. To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication. It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
