SOURCE: Sub-Zero 550
Hi!
I had the same problem with my 550...several times the tech came out and used a steam machine to blow out the drain...which didn't solve the problem. Finally, they ordered a refrigerator drain heater from sub-zero (part#4201290) and this finally fixed the problem. Hope this helps...I'm not a tech, just a customer. K
SOURCE: broken pdp glass
YOU MUST REPLACE THE PANEL...PROBABLY CHEAPER TO BUY NEW SET..DONT EVEN TRY..JOE ACE
SOURCE: Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
SOURCE: how remove the rear inside door panel on a 2001 oldmobile aurora
The inner door panel is held in by clips and screw.
Look at the door near the door handle there should be screws holding it in and along the outer edge of the door. Once loose, and the door handle removed or the arm rest removed. The door panel then prys out , because of the clips that hold it on. Then pops out by applying pressure to the panel upward to the top of the door. The clips always break because of the design and plastic.
Good luck
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
