I am work on a Delta 174WF with spray. When using the side spray. A lot of water is still coming out of the Main spout. Where is the diverter located. Where can I find the diverter? Thank I am a plumber for 38 years. I know all about the 100 WF & the 100 DS. Thanks for your help. I am on a job sooner the better
Http://www.plumbingwarehouse.com/delta-single-handle-faucet-172-173-174-176-178.html
Replace hose and sprayer, It operates the same as a 100
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
SOURCE: delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
SOURCE: My Delta 174--WF has a constant drip from the
Turn off water supply and use allen wrench to remove handle then remove bonnet nut then remove internal parts replacement kits available at most lowe's and other home improvement or hardware store or plumbing supply stores take care to document how everything is removed so you can reinstall exactly how it came out.
Probably needs a new washer.
