SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
SOURCE: Fuel pet **** came loose from fuel tank...
It's a rubber grommet available from eReplacement Parts for $1.84. Part # GS-0446.
Their link is ereplacementparts.com
Phone: 866-802-6383
I just got a new one for my tank. Had to order 3 as they have a $5.00 minimum order.
SOURCE: 1980 gs 1000 fuel petcock has two connections where do they go?
On the one that has two hoses does it still have an "Off" position? Usually petcocks that have two hoses, one goes to the carb vacuum, and the other is for a fuel supply for the engine. That way it only allows fuel to flow when the engine is running. I have found these to be a poor design and can often leak and allow fuel to run into the engine if your carbs are acting up. If the replacement only has one hose, then it will work fine, just be sure to cap off the vacuum port on the carb.
SOURCE: I have a Generac 5000 Power Plus 10HP Model
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg:
GENERAC
Part Number:
GEN 78298
This Part has
been superseded
Part Number:
GEN 080270
Price:
$5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
