SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
SOURCE: New power supply, but turning on no signal to monitor
well this is one of the nightmare problems I keep got into ..there can be alot of posibilities..but the most common are the video card is damdaged or the mainboard.try to change the video card and check than.if the problem persists,than is a motheboard fault..look to all the condensors,chech the intefrity of your connections..
good luck.
it is a very booring work.
SOURCE: Dish Network "Blue" Smart Card upgrade... Now get only "015"
The solution is usually a simple one and that has been suggested already but I will ask you to try one thing first. Remove the new smartcard and do not put one in. If the receiver still displays a picture and yoou can get to menu 611 run a check switch. After this is performed cancel out of the screens and re insert the new smartcard. Once the system comes back up perform the same steps as you did before with the smart card removed. If this fails you can try the solution they offered which was to update the sofware. There is no reason your software should be outdated if you were using this receiver before the new smartcard but try anyway as it may SOMEHOW work. Using the remote turn the receiver itself off. Allow the receiver sometime to turn itself back on-this could take awhile so plan this when you leave for work or are going to be gone from the house for sometime so you do not get bored waiting for this to occur. If the receiver has not turned back on in 45 minutes or more then the receiver will either need replacing -which i suggest- or they will try to send you a new smartcard if you talk to Cust service. Tell them you want a service call to fix the receiver. While you have them on the phone verify your receiver number and the new smartcard number which is on the back of the card and ask them to send a hit to the receiver. If the receiver has not been associated with the new smartcard or if the smartcard was not loaded with all of your programmming this should fix the issue. Thanks for using Fix Ya.
SOURCE: Won't start. Light on next to "heated dry" button & "#3" graphic
You have the lock activated. press and hold the HEATED DRY button for 3 seconds
SOURCE: OPTIPLEX 960 error codes 1 and 3 at startup
Blinking amber ... seems like an isuue with the power supply .. check if you see the power supply fan spinning at the back of the system tower... If its spinning then you could try reseating the memory modules inside the system tower . Opem the tower and then disconnect the green colour ruler shapped modules which has a latch on either sides. then try turning in the system ... check if turns on properly.
Hope its informative.
Testimonial: "Thank you - computer works with another power supply. You got it, Master!"
