I have complete board out and looking at it
SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
SOURCE: JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
SOURCE: Speaker was dropped - Tweeter Magnet came off -
Clean the mating surfaces very well, mark on the side of the magnet (arrow or dot) which surface of the magnet was glued (shouldn't make a bit of difference, I'm just a little anal) and then use any brand of quick setting 'super glue.'
This glue will not only hold well but will also introduce the thinnest film between the magnet and 'keeper.' Too much space between mating surfaces can weaken the field and reduce the efficiency causing an imbalance in volume relative to the other tweeter.
If anything else is loose, the tweeter is junk because any shift of the voice coil will cause the speaker to distort or rattle.
If you need to replace any speaker ever, replace both channels or have possibly lousy matching between channels.
SOURCE: I have a jbl eon g2 and used it at 1pm and then at
There is nan internal fuse right behind the board were you plug the power cable in. You have to split the cabinet to replace.
SOURCE: what is is the output IC no for the high driver of jbl eon
Download service manual here:
http://www.free-service-manuals.com/JBL_EON15-G2_Service_Manual_L38587/
