I can hear the arm rotating to move the ice through the chute however it is not producing any ice
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge? I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door. Let me know if you need more help. Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
SOURCE: Ice Dispenser problem on KitchenAid KSCS25INSS00 Refrigerator
You can download the repair manual or service manual for you Kichen Aid which you can find by using goolge just type
SERVICE MANUAL KITCHEN AID (model) Brand
and google it
here is a useful forum that contais extra information and some quick fixes http://www.applianceblog.com/mainforums/showthread.php?t=7374
SOURCE: ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
SOURCE: Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
SOURCE: door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
