Question about Masonry Tools
I am seeking a manual for a Morgan WJ150 Jointer.
Sorry for the multiple entries. Trying to ask question in the woodworking area.
    Top Expert:
  • 66,497 Answers
TRY THEIR WEBSITE
Posted on Dec 01, 2018
Testimonial: "I would if I knew what the website was :)"
  • ray gallant Dec 02, 2018
    TRY MRGAMTOOLS.COM
  • Ron Thornton
    Ron Thornton Dec 03, 2018
    URL does not exist :(
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: I'm seeking an owners manual
http://www.ozarkwoodworker.com/item/rockwell-6-jointer-instruction-and-parts-manual/
Posted on Sep 04, 2010
WHO R U ??
Hello Corrinne Palmer,
Not entirely sure what you are seeking...
(but you definitely wont get far with "SIMTH").
You won't find anything of significance until you
spell "SIMTH" as SMITH...
(computers are not forgiving)...
Sorry!
W R U (@ me?) = nobody.
Carnac the Magnificent
Mar 13, 2017 | Computers & Internet
Blades for 6" planer jointer naerok
The jointer planer knives is most helpful for woodworking . If you want blades for jointer planer machine Refer Or Contact below Link :
https://www.woodfordtooling.com/planer-blades-by-machine-model/jet-jointer-knives.html
The Woodfordtooling is online shop for all types blades planer blades , tersa knives , bandsaw blades and other woodworking tools at UK And all over world
Mar 09, 2016 | Crafts & Hobbies
General International General Woodworking Machinery 80-300 M1 12 parts
That lock knob should be available through General. I see them having stock so should be easy!
Quote your machine modle and ser #
Feb 05, 2014 | General International General Woodworking...
I need a downloadable parts and assembly book for a craftsman 21706 planer/jointer. can you help me
you can try at "managemyhome.com" that is where most of the Craftsman manuals are
Sep 23, 2010 | Craftsman 1212 in Thickness Planer
I'm seeking an owners manual for a Rockwell Jointer model 6
Sep 04, 2010 | Garden
Can not find replacement blades for delta jointer
I can't get a hit on that number, the model must be other. But it shouldn't be too hard.
Try to find a reliable sharpening service in your area; someone who does saw blades and knives for the cabinet shops will have a source for tool steel and carbide and can make you a set of knives for your jointer. Just get tool steel. While it won't hold it's edge quite as long as carbide knives, it will take a sharper edge to begin with, and should last just fine if you don't run sand through it.
If you have the original knives, hang onto them as they most likely can be resharpened to like new condition, and steel today ain't necessarily what it used to be.
The critical factor is the height. It's usually between 5/8" and 3/4" tall. You want them to be able to rest all the way down on the adjustable pistons without sticking up more than 10-15 thousands above the cutterhead. That will give you the most resharpenings from a set. You might want to invest in a magnaset to help with setting the knives in place.
Here's a link to the sharpening service I use: http://maps.google.com/maps?rls=com.microsoft:en-us&oe=UTF-8&um=1&ie=UTF-8&q=Precision+sharpening+%2B+Albuquerque,+NM&fb=1&split=1&gl=us&view=text&latlng=15322695688682105671
Finally, I would almost bet some contemporary delta replacement knives would work. If you find a place that will return your funds if they don't, you might be able to order them online. These guys will carry them if you can't find someone nearer you: http://woodworker.com
If I've answered your question or solved a problem, please take a moment to rate this posting...thanks!
Mar 04, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Planer or Jointer
If I had to pick, I would get the planer first. That way you can at least get your lumber pretty darn close to flat and parallel. Furthermore you can resize your lumber when necessary. But that’s just my opinion.
Aug 27, 2008 | Rockler 24? Precision Straight Edge
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Masonry Tools Logo
275 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Masonry Tool Expert? Answer questions, earn points and help others
