SOURCE: I need instructions for a LANDICE L7 LTD PRO SPORTS treadmill
You can get the manual on link below.
http://site.thefitnessoutlet.com/landice/LandicePTManual.pdf
SOURCE: landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
[email protected]
SOURCE: landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
SOURCE: landice L8 automatically turns on by itself
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
SOURCE: Motor or belt sqeals -
this may require proper troubleshooting but it is either the belts on the motor needs changing or the track belt ihas come to the end of it's usage life... but check thorougly.
