Question about Water Filters & Coolers
We have an SE80094-1 water cooler need a support collar
    Top Expert:
  • Water Filter... Master
  • 55,370 Answers
Order from the manufacturer/distributor
Posted on Nov 27, 2018
6ya staff
SOURCE:
How to properly clean my pelonis water cooler
not sure if this will help you out but have a read up.
To clean the cooler:
  1. Unplug the cooler.
  2. Check to see if your cooler is equipped with a water guard. ...
  3. If you do have a waterguard you need to remove it. ...
  4. Rinse the reservoir out with a baking soda and water solution, use approximately 1 cup of water and 2 tbsp of baking soda. ...
  5. Replace the water guard kit.
The Water Express :: How to Clean Your Cooler.
or go to this link.
How to properly clean my pelonis water cooler Google Search
Oct 30, 2017 | Pelonis Heating & Cooling
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Elkay water fountain, model# erpb2_8c,how do I take apart to replace water spout?
There are between two and four screws, probably 1/4' or 5/16' hex, on the underside of the cooler. Remove them. Make sure the water is shut. There should be a valve similar to those found under your bathroom or kitchen sink coming out of the wall where your cooler is mounted. Locate the plastic tubing that supplies water to the bubbler, (water spout), and press in the collet. The collet is a collar that slides back and releases the tubing. While pressing the collet, pull on the tubing. It should slide right out. Now you must remove the mounting nut, and viola! You can remove the bubbler.
Jul 18, 2014 | Home
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
Where is crank sensor on 2005 PT Cruiser? It absolutely is not above the oil filter as on 01-03 PT's.
REMOVAL - 2.0, 2.4, 2.4L TURBO
The Crankshaft Position Sensor is in the front of the engine block just under the starter motor (CRANKSHAFT POSITION SENSOR LOCATION).
Disconnect the negative battery cable.
Raise vehicle and support.
On 2.4L SRT-4 remove the lower inner cooler hose from the metal tube.
Remove the Structural Collar (Structural Collar and Bending Strut-(Automatic Transaxle Equipped) ), refer to the Engine, Structural Collar Removal and Installation section.
Unlock and disconnect the electrical connector to the crankshaft position sensor.
Remove the crankshaft position sensor bolt.
Remove the sensor. Arrow points to sensor in picture.
Aug 22, 2011 | 2005 Chrysler PT Cruiser
My 97dodge intrepid is leaking oil and i want to know where is the oil pan?
Hi. You might need to Replace the oil pan gasket is the oil is leaking. Here's the procedure on how to Replace the oil pan gasket.
1. Jack up the front end of the car and slide a jack stand under the vehicle. Make sure the jack stand is securely in place, and then put blocks in front of the rear wheels to keep them from rolling.
2. Slide under the car and put a drain pan under the drain plug of the oil pan. Loosen the drain plug with a socket wrench and allow all of the old oil to drain into the pan. Remove the old oil filter.
3. Disconnect the negative battery cable and remove the dipstick and its housing. Remove the collar on the rear of the oil pan. If the vehicle is equipped with engine oil cooler lines that lead to the oil pan, remove them as well, along with transmission oil cooler clips.
4. Remove the bolts holding the oil pan, and carefully remove the oil pan. Remove the old gasket. Scrape it with a putty knife if necessary, but be very careful not to scratch the surface.
5. Wipe out the oil pan with a clean cloth or paper towel, and wipe the joining surface of the oil pan with cleaning fluid or solvent. Apply a thin bead of automotive sealer and install the new gasket.
6. Replace the oil pan, tightening the bolts securely. Replace the transmission oil cooler clips, engine oil cooler lines, oil pan collar, dipstick housing and dipstick, and reconnect the negative battery cable. Install a new oil filter.
7. Take the car off the jack stand and fill the engine with the appropriate amount of SAE 10W-30 or SAE 5W-30.
All the best!
Nov 09, 2010 | 1997 Dodge Intrepid
How to replace 2002 pt cruiser starter
2.4L Non-Turbo Engine
Remove or disconnect the following:
Negative battery cable Air cleaner box cover Engine structural collar Starter electrical connectors Starter To install:
  1. Install the starter and torque the bolts to 40 ft. lbs. (54 Nm). Attach the starter electrical connectors.
  2. Install the engine structural collar on models with a automatic transaxle as follows, refer to the illustration for bolt locations:
    1. Place the collar in position and hand tighten the collar to transaxle bolt.
    2. Position the power steering hose support bracket and install the collar to oil pan bolt.
    3. Place the bending strut in place and hand start the bolt.
    4. Install the bolt through the strut and collar and hand tighten.
    5. Place the power steering hose support bracket in position and install and hand tighten the remaining bolts.
    6. Tighten the collar-to-transmission bolts to 75 ft. lbs. (101 Nm).
    7. Install the bolts through the strut and into the block.
    8. Tighten the remaining bolts to 45 ft. lbs. (61 Nm).
  3. Install the engine structural collar on models with a manual transaxle as follows, refer to the illustration for bolt locations:
    3. Position the clutch slave cylinder into position and hand start the bolts.
    4. Tighten bolts (1) to 75 ft. lbs. (101 Nm).
    5. Tighten bolts (2 and 5) to 45 ft. lbs. (61 Nm).
    6. Tighten bolts (3 and 4) to 20 ft. lbs. (28 Nm).
  4. Install the air cleaner box cover and connect the negative battery cable.
2.4L Turbo Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner box cover Upper starter bolt by pushing the inner cooler up and out of the way Inner cooler lower hose from the inner cooler Nuts retaining the inner cooler tube Studs retaining the power steering lines Position the power steering lines aside Engine structural collar Starter electrical connectors Starter
To install:
  4. Install or connect the following:
    Power steering lines aside Studs retaining the power steering lines and tighten to 45 ft. lbs. (61 Nm) Nuts retaining the inner cooler tube Inner cooler lower hose to the inner cooler Upper starter bolt by pushing the inner cooler up and out of the way. Tighten to 40 ft. lbs. (54 Nm). Air cleaner box cover Negative battery cable
Jul 03, 2010 | 2002 Chrysler PT Cruiser
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the...
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
The shaft on the master cool is moving from side to side and it vibrates. how do I stop it from moving
You need a couple of locking collars to keep the shaft from sliding around inside the bearing mounts.
You'll have to take the pulley off and possibly the bearings to insert the locking collars in between key areas where the collars can keep the shaft from moving in and out. You'll need to know the size of the shat (probably 3/4") to know which collars to get. You can find them online at www.indoorcomfortsupply.com
You'll probably want some leather washers also to eliminate friction between metal parts.
Jul 03, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water Filters & Coolers Logo
227 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
