SOURCE: power draw on start up
When the compressor first starts up it can draw as high as 15 amps but for no more then a second or two. After that it should run at 1-1.5 amp and will draw less as it continues to run. After 10 minutes it should pull anywhere from .5-1 amps.
SOURCE: Bottom Freezer Profile fridge does
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: it appears my refridgerator motor has stopped. The
Hi, If
you are hearing a clicking or buzzing then check out the last two
tips.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
heatman101
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
