SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
SOURCE: Sanyo DS24424 TV out put jack
I too have the same problem. Not sure whether Sanyo folks have provided such basic stuff in their TV sets.
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
SOURCE: Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
SOURCE: tv has no audio out jack
HI, use a scart adaptor to get phono audio out puts from your tv,be sure to use the scart which gives audio out this is the one with a box and arrows pointing in &out can be a little hard to see so if you have no sound try the other scart.
Hope this helps.
CABLE GUY.
50ohm and 75 All types of Coax We Customize Coax Assemblies
prolinkproducts.com/
