SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 – Fax 01628 776345 - Spares Email is [email protected]
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
SOURCE: delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
SOURCE: Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
