Loosen the top tension and lengthen the stitch length all the way Then sew two lines of stitches about 1/8" to 1/4" apart.
How to Gather Fabric and Make Ruffles
SOURCE: reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
SOURCE: the bobincase springs up giving no stitch in singer inspiration
Try buying a new bobbin case, it probably was damaged by jumping out of position.
SOURCE: I have a Singer 6202 and the stitches stay tiny
check your needle to make sure it's not bent--take the needle & roll it on a flat surface to see if it rolls good
the feed dog help the fabric move -check your operation manual to see if the feeddog is in the proper positon-if it's in the proper postion
you might want the sewing machine check by a service technican
good luck
please rate this using the thumbs ,thank you
SOURCE: Every few stitches thread gathers
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
SOURCE: upper thread cuts in singer sewing machine 3321 mode
replace the needle
check on the needle plate for burrs or on the bobbin case
