SOURCE: i cant remember my security code
go to www.nfader.su.........there enter your imei no. you will get a master unlock code. you can use it to unlock your phone...
SOURCE: my g2 is not switchng on, dnt knw y and also i dnt
Try this link:http://www.furtadosonline.com/contact.htm
SOURCE: i hav a samsung gravity
Hi, Is your network service provider is T-Mobile. If so please follow the instructions from this link :)
http://www.ehow.com/how_7244582_unlock-lock-samsung-sgh-t459.html
Please let me know if you need more help:) and kindly vote if you think this solution might help others.Thank you :)
SOURCE: i ave a htc smart
It is the sim card that got blocked not the phone. it is found in the Sim pack. It is the 8 digits code that you find on the Sim card carrier. Phones do not require PUK code, the Sim card does.
Check on the Sim cards pack, you will see the Sim card carrier where you broke the Sim card out of, there are some codes on it. You will see your number, the pin code and a 8 digit code, then you will see the bar code at the bottom of the card, it is the 8 digit code that is the PUK for your Vectone mobile.
If you do not have your pack anymore, what you have to do is to contact the Vectones customer care center, so they will be able to give you your PUK code, but the y will ask you for some security informations, which are easy to answer, after providing the answers, they will give you your PUK code.
Hope this helped.
SOURCE: my PIN is bloked n its asking me PUK code. i dnt
the following codes are provided by the network operator:
-pin code
-puk code
both of these codes are provided when you purchase a sim card and are usually written on the sim holder or on the provided booklet.
if u have the puk code, then u can enter a wrong pin multiple time and then the sim card will ask you for the puk code which then u can use to unlock the sim.
if u lost both the sim and puk, then the only way is to contact the network operator to give you a new sim card.
Don't try to enter a PUK code without knowing the right one.
hope this helps
