Here you go... You have to open it up. At the base of the motor is a piece of the shaft. It is notched. Put a crescent wrench on it to hold it steady. Then unscrew the head.
Ryobi or online search for replacement parts
Go to ryobi website and get a user manual
Https://m.youtube.com/watch?v=eOQGcc63iME
Maybe this helps?
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Testimonial: "Thank you! Just what I needed."
SOURCE: remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
SOURCE: Ryobi string trimmer -weed eater pull cord hangs out wont start
What model number is your Ryobi?
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
