SOURCE: Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
SOURCE: Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
SOURCE: ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
SOURCE: why is there heavy ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
