Washing Machines Logo
Jerry Marks Posted on Nov 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg front load washer will not spin - LG Washing Machines
Chris Huff
Level 3:
Top Expert:
  • LG Master 6,289 Answers
  • Posted on Nov 04, 2018
Chris Huff
LG Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020233
Points
74913
Could be belt issue or control board issue or possibly door latch / lock issue.
Michael LeCroy
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 164 Answers
Michael LeCroy
Expert
Level 2:
Passionate:
Answers
164
Questions
0
Helped
233217
Points
359
No belts on any LG ever in the history of LG. Could be a number of things causing an issue. Most common are drain pump/coin trap is clogged or door lock is faulty.
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Lg wh2277hw will not spin. takes water and attempts to spin but no.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
1helpful
2answers
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
1helpful
Washer will not drain or spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
My LG washer wm2277hw does not drain water and
Front Load Washing Machine not draining and or not spinning
heatman101
Front loading lg washer
if you have the spin sense option, try enbaling that on the washer
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
