SOURCE: Bosch Vision 300/500/dlx Series Clothes
Im getting an error e13 message and don't know what to do
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock. If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
You first of all need to
check the pump filter. This is
located at the bottom front right of washer. Look for a drop down flap or cover, once
located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and
junk. The pump itself is directly behind
the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is
water in the washer, just some kind of precaution, so don't force the door.
Pl click helped, if helped
