Steamist sm 46 error code e6 steam unit won't start
SOURCE: error code Prr
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
SOURCE: I have a Steamist SM-8
1) Steamist SM-8 is a Steambath steam generator with 5 year parts warranty and 2 years labor
http://www.faucetdepot.com/prod/Steamist-SM-8-IM-InstaMist-Steambath-Steam-Generator-29984.asp
2) Steamist website does not have manuals that we can immediately download and look at error codes alongside you.
http://www.steamist.com/
3) However your manual has that information, and you can add a comment and say what the manual suggests as troubleshooting, so we can offer some level of do-it-yourself help.
4) Perhaps you could scan your manual into pdf format and post your manual on your website.
And then add a comment with web location of manual so we can download and read your manual, alongside you, and perhaps offer additional do-it-yourself solution for you.
For example check that circuit breaker is delivering 240V to product, and element is not burned out, and there are no loose wires, and condensing reservoir is not clogged with sediments that can be cleaned with CLR.
5) The manual is key: I'm sure the manual also shows regular maintenance needed to ensure long life of product. For example avoid exposure to hard water, use water filter, clean reservoir and lines regularly. Avoid freezing.
I always tell people to save product manual like gold and read it cover to cover because it will save money and trouble long-run.
6) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician to make repairs.
http://www.steamist.com/contact.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on steamer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: i have a steamist smc-150 control that won't power
Contact Steamist directly for manual, DIY troubleshoot, warranty, etc:
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on any do-it-yourself project.
SOURCE: Mr. Steam Prr erro
my mr steam goes on by itself sometimes in the middle of the night...or in the day....why does this happen
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
