SOURCE: Disconnect Audible Alarm
Sorry but some models cannot shut off the alarms. The newer models can.
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
SOURCE: amana SBDE520N
HELLO, MY NAME IS TZINAS JOHN FROM GREECE AND I HAVE A PROBLEM WITH THE WRITE DOOR OF MY FREEZE.
THE MODEL IS * SBDE520S W *
THE PROBLEM IS THAT IT GET IT ALL THE DOOR DOWN FROM THE DOWN SIDE OF THIS.
I HAVE FIND THAT THE PROBLEM IS TO A LITLE PLASTIC PEASE FROM THE DOWN SIDE OF THE DOOR.
PLEASE CAN HELP ME WHERE I CAN FIND THIS PART???
SOURCE: Refrigerator will not stay cold
Eeeh, this will prevent you to spend more than you have. Carefully unplug your fridge, remove it from the wall for about 1 foot wait 15 mins and plug back and let it stay there for ever.
Hello friend, thank you for your post!
Your high temp alarm will sound once your refrigerator temperature rises to an unstable temperature on the inside of your appliance. If you refrigerator is cooling properly I would recommend resetting your appliance which can be done by disconnecting the power to your appliance for roughly ten minutes. If this does not correct the issue, I would recommend having a professional come and diagnose your appliance properly. Hopefully this is helpful. -Matt
