Question about Hobart Welding Tools
I need a gun for the Hobart beta mig 170 welding machine
  • CANICAZ 15
    CANICAZ 15 Apr 13, 2019
    if u still need the gun for the HOBART beta mig 170 call me (562)787-9250
  • Hobart Master
  • 6,023 Answers
Lots of torches are fairly universal and you are likely to find it cheaper to replace only the parts needed if you can find them - manufacturers tend to prefer to sell the torch (or gun) complete with the hose, cables and sheath and they are expensive though considerable savings can be made dealing with factors or independent supplier/repairers.
Most professional mig welders over here use the euro torch and when a welder doesn't have one and the torch is ready for replacing it is a worthwhile modification, especially if the necessary parts can be sourced secondhand or salvaged.
The euro torch just plugs into the machine and once the machine has been modified there are plenty of usable secondhand ones about that can be had for a song.
If you aren't conversant with the euro torch, try a search...
Posted on Oct 29, 2018
  • 414 Answers
Call your nearest praxair branch they carry guns for all models in stock. You don't have to buy the original.
Posted on Oct 05, 2019
5 Suggested Answers
6ya staff
SOURCE:
luis_david
David Soto
  • 414 Answers
SOURCE: Hi i have a
Hobart machines now belong to miller brand, you can use a miller gun M15, no need for adaptors it's a direct plug connection. Praxair stores carry a cheaper gun under prostar label a 150amp gun will cost you around 150 bucks.
Posted on Jan 13, 2011
luxur4
Ron Jones
  • 92 Answers
SOURCE: I need a liner for a Hobart Beta Mig II so I can
You can buy liners for torches from most welding suppliers, if the torch is very old, it may be time to update.
Posted on Nov 20, 2009
vloster
  • 3 Answers
SOURCE: currently welding with fluxcore wire in my hobart
you need ar/co2 95 5 change contact tip to what ever size wire you r going 2 use .035 .045 whatever
Posted on Dec 10, 2010
Earl P
  • 35 Answers
SOURCE: Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Posted on Jan 17, 2011
Where can I find nozzles pn 379718 & nozzle adaptors pn 379708 for a Hobart beta-mig 170 with Hobart gun? thx bob
Bob,
Those parts have long been discontinued. www.usaweld.com might have an adapter kit if you have a piecemaker 14A gun, or they have a complete replacement welding gun.
Jun 04, 2015 | Hobart Welding Tools
Where can I get parts for a Hobart beta mig 170? Need 379718 nozzles & 379708 nozzle adaptors for Hobart gun. thx bob
Those parts have long been discontinued. www.usaweld.com has a conversion kit that will convert the original Piecemaker 14A gun to the current hobart H10 parts.
Jun 03, 2015 | Hobart Welding Tools
I have a hobart beta-mig 170 welder that I just put a new wire feed motor on but still won't work. The old motor I could tap on every now and then until it just quit. Any ideas?
Check the Switch on the handle. Many times the two wires from the trigger down to the Mig Unit break or get a bad connection
Jun 01, 2015 | Hobart Welding Tools
I have an older Hobart beta mig II welder and the drive motor does not work when trigger is pulled. any ideas
Hi:
have you tried to by-pass the gun switch by disconnecting the gun cable (not the lead) and using a paper clip to by-pass the gun?. If the motor turns then you need to replace the gun switch if not probably the PC board fuse it's blown.
Jun 24, 2011 | Hobart Welding Tools
I will make about 12 3" passes over 3" square
Nothing's wrong with your gun or machine. Your unit has a duty cycle of 20 percent at 90 amps, meaning that it will work (weld) great for 2 straight minutes and then it needs to cool down for 8 minutes. The duty cycle it is measure in 10 minutes lapses.
All you need to do is to let it cool down, and start again. That's all.
Jan 19, 2011 | Hobart Handler 140 Mig Welder
Currently welding with fluxcore wire in my hobart 140, do I have to buy another mig gun to weld solid wire and using argon/co2 gas mixture?
Dec 10, 2010 | Hobart Welding Tools
Hi i have a Hobart Beta-Mig 200 and i need a all new gun and wip.
Oct 27, 2010 | Hobart Welding Tools
Welding aluminum and wire keepscoming out of rollers
your hobart machine it's not suit up for standard aluminum welding, the lenght of the gun it's too long therefore the wire will nest at the drive rolls. You need to buy a spool gun. Or change gun liner for a teflon one (instead of metal one), then change the drive roll for knurled ones and finally oversize your tip if you can. No need to do ALL this if you buy a spool gun.
Oct 24, 2010 | Hobart Handler 140 Mig Welder
Feb 25, 2010 | Hobart Welding Tools
I need a liner for a Hobart Beta Mig II so I can weld aluminum. Any ideas on where to find one online?
Mar 25, 2009 | Welding Tools
Welding Tools Logo
483 people viewed this question
Top Hobart Welding Tools Experts
David Soto
David Soto
rjivaro
Bryan Epland
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
