Please provide more detail such as manufacturer and model number. You may also want to Google this information and look for a user manual. I am sure the information you are seeking will be included.
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
SOURCE: charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
SOURCE: yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
