SOURCE: Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
SOURCE: my rio ce2100 keeps stuttering or skipping
I would recommend wiping your player - (if this doesn't work then it is probably the tracks/audio you are playing and not the player):
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio carbon and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then
when it has finished formatting go to your firmware (can be downloaded
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
SOURCE: My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
SOURCE: hi, my machine starts for a few seconds then stops
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
later
SOURCE: wenger watch second hand pauses and skips ahead 4
That is a low battery indicator. It will do that until the battery is replaced or is dead. When it does that it means its time to change the battery.
