All routers can be logged into if you have a Browser & type in the IP address in the URL box (default or new) (e.g. 192.168.1.1) and use the default username & password. Often Admin , Admin
Defaults are often on bottom of router
Then you go to the Password setup page & set up for WPA-PSK /WPA 2-PSK and set some letters & Numbers for your password.
I have EXACTLY the same problem with a brand new 2797... but have concluded that I must return it to Garmin as I can't see the screen during daylight hours; tried EVERYTHING... was this your "solution"?
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Restoring it to default factory settings will not remove the pin. This is a safety feature to prevent people who steal them being able to use them. You may still be able to get by it though. There's information on how this may be possible at http://www.fixya.com/support/r6240807-remove_forgotten_pin_from_garmin_nuvi
1234 is the new master code, 4112 is the installer code to get into programming. If you defaulted the panel, all previous zone programming is lost as well as reporting methods and types for those zones. Basically it's set back to the way it came out of the box!
What type of panel is it? Do you have the manuals?
Access Control Panel; goto system information and check to see if a driver is installed for your cd rom. If not, try installing using the "add hardware" feature of Control Panel. Also make sure the cd rom drive has the power and IDE cable properly installed.
Install the software first, then connect the printer. Once all drivers are installed go to start, settings, printers. Find the printer, right mouse click on it and choose "set as default printer", that's it.
