The internal rechargeable batteries may have failed.
Even when not used, the electrolyte can leak out,
weakening the Ah capacity.
If not still under warranty, see if you can remove the housing and check if cells have a white, crusty residue, which means they have leaked.
If no screws are visible, splitting the two halves of a hand-blender can be a mission - sometimes needing to squeeze one cover-side in a padded vice to release internal hooks.
SOURCE: instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise
1 egg (or 1 egg yolk)
1 teaspoon of lemon juice
1 teaspoon of herb vinegar
1 pinch salt
1 pinch pepper
1 ½ - 2 cups of oil
1 teaspoon of french mustard
Put all the ingredients except the oil in a jug (not too large)
and blend well with the WHISK. Then add the oil in a thin, steady
stream (not drop by drop), processing all the time, until the
mayonnaise has reached the required consistency. To achieve perfect
results, all ingredients should be at the same temperature.
go back
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
SOURCE: no power, removed batteries, no charge below .4
Make sure the charger is working...take it to your nearest BatteriesPlus...www.batteriesplus.com
SOURCE: BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
SOURCE: Hi I lost the Wolfgang
