Heating & Cooling Logo
Dom Yac Posted on Oct 14, 2018
I have a older Goldstar GWHD 5000 window unit AC ..I put a hole in the copper line and all the freon leaked out ...on accident..can I fix the hole ...if so can I add freon..I have some R12
No need new cooling unit
1 Related Answer
Anonymous
  • 398 Answers
  • Posted on Jul 31, 2009
SOURCE: Water leak from Goldstar GWHD 5000 window ac unit.
ok what you need to do, get someone to pull the a/c out and clean it. it gets full of dust and it sticks to the coils the garden hose will clean it out. be sure to clean out the drain holes so the water will drain outside like it should. one more thing besure the a/c is tilting down to the outside so the water wont leak in your house. have a good day you can do ths.
2helpful
3answers
How do i fix and replace a freon leak?
If the leak is able to be seen and easy to get at you might want to take it where they replace parts for fridges and see if they can solder the holes. That's what repair people do when you have a Freon leak in a fridge.
The copper coil line got a litle hole in it,
After the hole was repaired; did the serviceman charge your system with Freon? This would need to be done as any leaks in a ac system will empty the charge in a short amount of time. window units usually have a very small Freon charge due to the small size.
1helpful
The copper coil had a hole in it and all the r134a leaked out. I fixed the hole but cant find a spot to add new r134a? My car is easy to add it too, I thought it would be similar? Its a LG window unit....
Hello, in order To charge freon into tne system you need to add piercing valves to the low and high sides of the system. Here is a link to pierving valves http://www.apwagner.com/index.php?main_page=index&cPath=5_227
1helpful
2answers
I have a Goodman home A/C unit and the copper line coming into the house freezes up. The unit continues to run with no cold air. I was told it is either dirty or low on Freon. Are they correct? If it is...
Hello
If you have ice on bigger copper line and no cooling then the unit is low in freon.
As far as cleaning it,you should clean the outside condenser in the spring.Use some simple green and a hose to clean the coils,this will make it better for the heat to transfer to the outside and cut your costs of running the unit down.
No you can not do freon yourself you need to be cfc certified now,which means you can not buy freon.Best to have a service person come out.
4helpful
3answers
I have a 15btu ac on my rv with a closed system how do i add freon
Only someone who has the tools, and is certified to work with refrigerants should do that. If your unit is not cooling, first check to make sure the air filter is not plugged up. (It is usually a foam washable filter, behind the air return grill, on the ceiling of your RV, directly below the A/C unit)
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Ac blowing hot air
Sounds like you have a good sized leak in the system. The service man should be able to locate a leak that big. You might be able to locate it yourself. It's more than likely in the outside unit or indoor coil not in the lines that run between them. Look in the outdoor unit and look for any oily spots. The compressor has oil in it and it will show up where there is a leak. Look for any pipes that may be rubbing together as this will rub a hole in a line. Look at the indoor coil looking for the same indications. Hope this helps.
2answers
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
2helpful
Water leak from Goldstar GWHD 5000 window ac unit. No past problem in use over 8 months. Thanks.
2helpful
2answers
Goldstar GWDH 5000 does not cool after storing this winter
sounds like low freon or a blockage in one of the lines, especially since the you say only one row of coils is cool. usually window a/c's have at least a 1-year warranty and since you are pretty close to that, the manufacturer may honor it. if not you will need to have the system fitted with a bullet piercing valve on the low side lines and see if the unit is low on freon with proper gauges. if it is not showing low then there is probably a blockage and the high side should be checked as well. if this unit was an expensive one it could be worth having it repaired. a simple recharge may cost less than a replacement, but anything else probably won't.
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
