SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
SOURCE: Would like wiring diagram for starter selonoid for
Hopefully this will be what your looking for if not let me know.
SOURCE: no spark for a craftsman
Get the Sears model number from the machine and go to: www.searspartsdirect.com Look to see from the drawings whether the engine is a points/condenser magneto or a composite ignition module. If it's a magneto system, the points may be dirty or mal-adjusted. The composite module is totally self contained and must be replaced if faulty. Make sure that the stop switch and wiring is working correctly. Hope this helps!
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
