Craftsman T1000 tractor running great. I shut it off; when I went to restart it turned over but wouldn't start. I figured the battery was weak so I put it on the charger. When I went to start it after charging I got nothing but a click. Tried a new battery but still nothing, any thoughts?
SOURCE: 601 ford tractor weak starting, battery runs down,
Check your ground(s) wire or something is left on like lights or some electric option or something is shorting out.
Testimonial: "I have limited knowledge about mechanics. The answer to my problem was right on the money. Thanks"
SOURCE: I have a craftsman lawnmower lt 2000 42 deck which
Where is the battery located on the LT2000 42"
SOURCE: craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
SOURCE: have a john deere sabre
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
SOURCE: hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Update, cleaned the terminals and she's running again
