Watches Logo
Armitron 75/3889 remove back - Armitron Watches
I have a Armitron watch and the back is warped can that be fix and how much?? Where could I send it to be repaired just the back. Thank you
You might try Esslingers first and simply see if they have a watch back.
Or put Armitron case back in the Search box of eBay
Good luck
1helpful
I bought an armitron watch online It is not working Does it come with a battery already in it or was there supposed to be one in the box with it? The only thing in the box was the instructions
check for a small bit of plastic under the winder knob
if it has it remove it and push the knob back in
new watches have this in place so that battery will not go flat in the show room or in stock
How do I set an armitron watch,the numbers on the back are 40/8089
Google ( armitron watch manual ) , there are a few different models on a youtube video, also a link to download manuals a little further down the page.
1helpful
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
1helpful
Instructions for setting amriton
From http://www.armitron.com/WatchInstructions.html
If you cannot locate your type of watch listed here, please refer to the back of the watch
case for our Armitron style number and contact us at 718.784.0700 for further help
5helpful
2answers
Armitron y121e watch
If your Armitron has a set of 6 inset notches around the back, as does my Y121E 20/1791F Armitron Diamond, that's a screw-back case that does _not_ pop off or pry off. You'll need a case opener tool, which is basically a small tool with adjustable-gap jaws that fit into two notches on opposite sides of the case and let you unscrew it. Wal-Mart sells this tool for about five bucks, and it'll pay for itself soon enough, as many watches have screw backs, and this will fit most anything you find. Head for their jewelry department and you should find the tool hanging up with the replacement watchbands and batteries.
The case is probably screwed down fairly tight against its O-ring seal, so make sure the tool is seated properly in the case notches, and turn it slowly and firmly counterclockwise to work it loose.
If your watch is like mine, it'll take a #377 cell, but wait until you've opened yours up to be sure.
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
