Depending on water condition, the valve core assy can be requiring new O rings. Chlorine will remove conditioning in the o ring and it can harden and shrink . I recommend coating prints and assy with silicone grease. This protection will last a very long time. Also if there are lime deposits on valve, that will require soaking valve core in vinegar to remove crustation. About 2 hours. Brush residue. Or purchase new cores. O rings are a real money saver.
Replaces the tap washer or insert
SOURCE: dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
SOURCE: I had a dripping Kohler Finial kitchen faucet
Any bit of dirt or grit in the line will get caught in the cartridge if not flushed properly.
SOURCE: my kohler k15160-96 kitchen faucet drips. . How
You will need to replace the cartridge in the faucet
SOURCE: Kohler parts - plumber told
hi, just had a quick look and the part you would have to source would be :78125 spline adapter. this is shown here...... http://www.us.kohler.com/onlinecatalog/pdf/1146603_2.pdf the taps are washerless ceramic valves and pretty good quality, are they still covered under warranty as i would imagine that part is not cheap.
