Music Logo
acab 1312 Posted on Oct 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Price on Beringer Europower PMP 3000 - Music
rhodesworks
Level 3:
Top Expert:
  • Music Master 3,159 Answers
  • Posted on Oct 30, 2018
rhodesworks
Music Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
561704
Points
331463
These are no longer made but I see them on the used market in the USA in the $200-250 range.
5 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Aug 27, 2009
SOURCE: i have a beringer eoropower pmp 5000. i run my
With the AB switch at the center position Mon1/Main you control the volumes INDIVIDUALLY with the MON pot for each input that is a couple positions above each of the input sliders.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 22, 2009
SOURCE: I have a beringer pmp 5000. Out of the box, I
Yes, the fan is temperature controlled. You have to drive it a bit before it runs, and then it is kind of throttled versus temperature.
Anonymous
  • 7191 Answers
  • Posted on Jan 15, 2010
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Fred Yearian
  • 5603 Answers
  • Posted on Feb 06, 2010
SOURCE: europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Anonymous
  • 2992 Answers
  • Posted on Jul 06, 2011
SOURCE: Fuse blown on Europower PMP
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Where can I send my Behringer EuroPower PMP 3000 12-Channel Powered Mixer for repair?
Question Edited to add make and (what it is). Please always include as it helps us to help you better.
Direct to the factory.
https://www.behringer.com/service.html
Dec 06, 2021 • Music
Pric on Europower PMP 3000
$185 to $300 used
Oct 06, 2018 • Music
I have my pc hooked via 1/8" to 1/4' to my europower pmp518m and my sound is very low, but my mics are very loud (need music loud also)
The 1/8 jackon the PC is Stereo so you would need a stereo splitter to then go into separate jacks or maybe tape input on the PMP. Plugging in a mono jack shorts out one side of the PC audio out. Make sure you use a splitter type and NOT a 1/8 to 1/4 stereo cable. It must split into TWO cablles to plug into the PMP.
Mar 12, 2013 • Music
I want to know how to send the signal from a Europower pmp 3000 to two external amps
Plug a balanced TRS (tip ring sleeve) cable into either main or monitor 1/4 inch jacks and then into the amp. ALWAYS use balanced lines AND power the mixer AND the amps from the SAME receptacle to avoid damage from ground loop bounce,
3helpful
2answers
Europower pmp 3000 120v or 220v ?
1helpful
2answers
1helpful
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
