Vacuums Logo
J
Janet Killen Posted on Oct 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Greyhound pet has had upset stomach - how do I clean carpet pls, Jan Killen>
Richard Mowbray
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Oct 22, 2019
Richard Mowbray
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
86
Points
10
Have pets running around your home? Whether it is a Greyhound or Chihuahua, a pet with an upset stomach is surely going to ruin your carpet glow. Most of the carpet cleaning experts will suggest you DIY methods that may include vinegar, baking soda or lemon. However, DIY methods hardly work for removing tough pet stains and foul smell. The best solution I can offer to clean your carpet easily is to dial a professional carpet cleaning service expert. If you are from MA, then you should book services of residential carpet cleaning expert Peabody online or pet stains removalists Peabody.
JC Meredith
Level 2:
Sergeant:
  • Expert 168 Answers
  • Posted on Oct 05, 2018
JC Meredith
Expert
Level 2:
Sergeant:
Answers
168
Questions
Helped
42850
Points
741
get the big stuff with paper towels in a used grocery bag. then we use white terry cloth rags with a weak solution of dish detergent and warm water. when the terry cloth isnt stained you got the stain up.
jm
1 Related Answer
Anonymous
  • 701 Answers
  • Posted on Dec 30, 2009
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
tip
HOW TO SPOT CLEAN A CARPET I have a "furry family" of a dog and 2...
I have a "furry family" of a dog and 2 cats who I love dearly. Unfortunately, my carpet has suffered from several "accidents" and "upset tummies". It is a challenge to find an effective cleaner that cleans the stain, reduces the odor in the carpet, and is reasonably priced.
In the past, I have tried commercial products that were both expensive and ineffective. I have also used vinegar mixed with water and, although it was effective, it did not achieve the results that I would have liked. So one day, I decided to mix a little scented fabric softener in with the vinegar and water and VOILA what a difference! It removed the stain and left the carpet soft and smelling fresh. It has become my preferred method of dealing with pet stains on the carpet.
If you decide to give this a try, be sure to test this solution on an inconspicuous place on your carpet to be sure it does not discolor or lighten it. So far, I have had only good results from its use.
To Spot Clean a small area:
  1. Fill an empty clean spray bottle with equal parts of water and vinegar. Then add a capful of scented fabric softener to the bottle. Shake it up for 30 seconds.
  2. Spray the stained area
  3. Let it sit for 2 minutes and then spray a little more on it.
  4. Rub the stain with a dry cloth until it disappears.
  5. The vinegar odor will fade as it dries and helps to remove the foul smell
  6. Let it dry and you will notice a nice fresh smell and your carpet will be soft.
  7. Once you vacuum, you will have a hard time telling where the stain was.
I have actually used the mixture above in my Bissell Carpet Cleaning machine with good results. It is much less expensive than commercial carpet cleaning solutions. Be sure to read your machine manual or contact the manufacturer to make sure it does not affect its operation. So far my machine is tolerating it well.
This is a personal tip that I just wanted to share with others. I hope you find it useful.
on Apr 12, 2011 • Vacuums
Suction problem? The carpet fiber and pet hair
You've probably got a lesser blockage further down the pipework, which is reducing the airflow. Check everywhere possible for blockages, and also make sure the washable filter is clean and dry.
Bissell Pet Hair Eraser Vacuum marking carpet
the brush is always turning on the machine even when your using the tools. try not to set it down on thick carpet , or if you can set it on the linoleum.
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
