SOURCE: How do I remove the clutch on an Echo chain saw??
Backwards to the rotation of the motor, all you need are basic tools to do this.
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
SOURCE: husqvarna chain saw clutch bearing removal
you need a specal tool to remove the clutch assy.it grabs the clutch assy. and you spin it reverse thread.most shops will only charge you a couple of bucks to remove and install it if you have the parts
SOURCE: ryobi chainsaw pcn4040 - oil not being pumped onto
C. Both A and B. Is it the original bar? Has it ever worked with this bar? Yes continue, no reply below (first). Is there an oiler adjustment?
I know you did this, I have OCD. Good on you for checking.
Oil System Plugged:
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
I did not see a match to your model. If you can find it the exploded parts list with disassembly/reassembly. Also provide part numbers, where components are located, very helpful.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
The 3 models I found all had inboard clutches and the oil pump behind them. Start with this:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Continue like this with the remaining pieces.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
If you need more help come back.Post /
thumbs / testimonial are
welcome!
