When you say that, this must be an older model LCD TV. In fact one of the best in my operation. Your power supply has two bad capacitors. I do not know your TV model number or I could give the correct values of capacitors. But actually an easy fix. Any hobbiest can fix this for you. Thanks for asking, Matt of Martins TV Repair.
Testimonial: "The model is UN65FH6001FXZA. I have looked at the power board and found no swelled or popped capacitors."
My mistake , it is an LED. Yes I have investigated and have actually looked at the power board. No popped or swollen capacitors. The model is UN65FH6001FXZA
Pull out the power supply board if you can. Look under the board. Inspect any and all solder on pins. Look for cracked rings around solder connections. Try that and contact me. Matt of Martins TV Repair.
