Televison & Video Logo
A
Anonymous Posted on Oct 03, 2018
My TV wont turn on
It's a 55 LG, it turns off by itself and then this morning I could 't get it to stay on
alanrsm
Level 2:
Habit-Forming:
  • Expert 95 Answers
  • Posted on Oct 04, 2018
alanrsm
Expert
Level 2:
Habit-Forming:
Answers
95
Questions
0
Helped
23130
Points
280
Did you power it on. Please send me your address and the name of your power company. I'll call them and have someone check the power lines.
matt martin
Level 3:
  • Televison & ... Master 1,259 Answers
matt martin
Level 3:
Answers
1259
Questions
12
Helped
297222
Points
3635
Need a model number. But I already know the problem. This is not an easy fix as told on You Tube. Under warranty would replace the panel (TV Screen). Replacing LEDs are next to impossible. I fixed these with warranty. Thanks for asking, Matt of Martins TV.
5 Related Answers
Anonymous
  • 108 Answers
  • Posted on Jan 11, 2009
SOURCE: When I turn my TV on, it automatically turns off and stays off.
check the lamp and air filter if there is one
Anonymous
  • Posted on Jan 28, 2009
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
timtation123
  • 56 Answers
  • Posted on Jul 15, 2009
SOURCE: sony wega hd tv will not stay on
Is your sleep timer on?
Anonymous
  • 416 Answers
  • Posted on Apr 19, 2010
SOURCE: LG Plasma TV automatic turn off right after turn on
You have some dried out capacitors on the power supply. Samsung has a major issue with this right now and I made a tutorial for that repair in my Tips & Tricks. Your capacitors will not be the same, but identifying them and replacing them will be. Best advise I can give you: Stop using the TV and unplug it until you get it fixed. When these caps go bad, they draw down the voltage they are filtering. I've seen some TVs that had secondary damage because of this. I hope this was of some assistance, best wishes.
George Kopp
  • 87 Answers
  • Posted on May 12, 2010
SOURCE: TV was on and shut off by itself. will not turn
Probably power supply, call Vizio for slow service
2answers
Good morning, my LG 55UF6450-UA is turning on & than shutting off a few minutes later. Could this problem be resolved by replacing the Power Supply / LED Driver Board? Please advise. Thanks.
If your LG TV is turning itself off, try the following
  1. Check the AC cord is plugged in properly
  2. Ensure the AC cord isn't damaged
  3. Test the power socket
  4. Reset the TV
  5. Deactivate Quick Start +
  6. Disable the auto power off
  7. Disable the power off timer
  8. Clear the cache
  9. Update your software
  10. Factory reset the TV
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Lg 55lh90 no sound
The set itself may have a hard reset--if what happened was a outage--unplug set, box if used, receiver if used and wait a while--plug all back and wait for any and all to come up--reboot to see if it helps or not.
If no sound via any input like a DVD etc check that speakers to set did not get switched to off by that event.
Failing these the set may have a audio circuit problem.
Tv wont turn on
hold the menu and input/device buttons for 5 seconds and it will blink you a 2 digit code
1-2 normal operation
2-3 i believe is short circuit protection = probably a convergence failure
here is a link to my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
2answers
10helpful
2answers
2helpful
2answers
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
