You just go to the link below, I'm sure you will get the solution of your problem
https://www.reliable-store.com/products/toro-powermax-snowthrower-snowblower-6000-726-826-828-1028-1128-service-manual
Hi, Steven Fixya is a Q&A website where regular folks ask questions and professional experts answer these questions to the best of their ability. Sadly you are not a professional or an expert. When you answer 100's of different questions in different categories with the "SAME EXACT" answer, you are wasting the people that asked the questions time, and you make Fixya look bad. It is quite obvious you have no intention of helping anyone and the only goal you have is to see yourself at the top of the leaderboard which makes you a genuine "POINTS CLOWN". If you continue your ridiculous behavior I will have you permanently terminated from the site. Try being more helpful with your answers. This is your first and last warning. Have a nice day.
SOURCE: How do you start the
use the primer bulb bulb and press it three times to fill the carburator with gas,then push the choke rod to the full right position and either start it with the pull rope or use the electric starter to start it,if it will not fire,then you have carburator problems, then remove the sediment bowl off the bottom of the carb and see how much junk is in this bowl and dump out,then reprime if needed, and then try a small amount of gas into the carb and see if it fires,if so then you need the carb cleaned out depending how plugged with gunk it is by either yourself or a professional,i own 3 of these machines and the gas they have now(especially) the "gasahol" E-10/E-15 blends are tough on these carbs,let me know how this works for you,and see if we can get this unit running for you!!! GREAT MACHINE when running!!!
SOURCE: which oil to use for toro model 826 le
Hello, Here is the oil and i am putting the website for you to have the specs for the engine on it too. The oil to use is 26 oz. (.8l) 5w-30 or 10w / API SH or higher. Toro
