Refrigerators Logo
JL Dorber Posted on Oct 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I stop my LG GR-L207QUJA SXS Refrigerator from making ice cubes or crushed ice
Michael LeCroy
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 164 Answers
  • Posted on Oct 02, 2018
Michael LeCroy
Expert
Level 2:
Passionate:
Answers
164
Questions
0
Helped
233158
Points
359
There is a switch or button on the door that says crush and cubed
Chris Huff
Level 3:
Top Expert:
  • LG Master 6,289 Answers
  • Posted on Oct 01, 2018
Chris Huff
LG Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018757
Points
74913
Cut water supply off or cut off ice maker switch.
5 Related Answers
Carmen Mikulic
  • 415 Answers
  • Posted on Sep 25, 2008
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Anonymous
  • 1543 Answers
  • Posted on Nov 25, 2008
SOURCE: Ice maker only makes crushed ice
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Mike Inman
  • 219 Answers
  • Posted on Mar 19, 2009
SOURCE: My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Anonymous
  • 103 Answers
  • Posted on Jun 03, 2009
SOURCE: can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
jeffbvegas1
Jeff Barton
  • 520 Answers
  • Posted on Jun 28, 2009
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
My lg refrigerator will only do crushed ice not cubes
crushed ice is better for your Margareta anyway... but chances are the switch or button that allows you to select crushed or cubed is broken...
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
1helpful
Ice Cube Size adjustmentsLG SXS Refrigerator. Model GR-L-207 DVZA
If you pull the front cover off the ice maker,You will see an adjustment srew with + and - symbol ,just turn that srew.
Please rate this a fixya
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Cubed versus Crushed Ice Cubes
I have the exact same problem with my LG SXS refrigerator.
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
3helpful
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
