Question about Grilling
I have a old trager(BBQ075) I want to put a new controller on it with the cooling it plug into my smoker?
    Habit-Forming:
  • 84 Answers
I'm not exactly sure what your question is from what you wrote, but if you're looking for either the new controller or info on its installation, contact Traeger directly: https://www.traegergrills.com/support
Posted on Feb 02, 2019
6ya staff
SOURCE:
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Traeger trip gfi
Could be the hot rod igniter has accumulated too much moisture.
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Feb 03, 2013 | Traeger Industries BBQ075 All-in-One Grill...
Traeger tripping gfi
Check this out: may be your hot rod has absorbed too much moisture
From Traeger:
One of the small wheels came off the grill as I was pushing out of my garage. The grill rolled on its back. I put the grill back upright and now when I plug it in and turn the digital dial it says...
Instead of taking it back to the store, which I don't think will solve the problem. As, it's not really a warranty issue. Contact Traeger Industries Technical Service Dept 800-872-3437 for a solution to the Error Code.
Apr 13, 2011 | Traeger Industries BBQ075 All-in-One Grill...
HOW DO YOU GET & PUT IN A HOT ROD FOR A BBQ075
You can go to www.traegergrills.com and go to the support tab and customer support can help you with getting a new hot rod and how to install it. You can also download a manual from this site. Hope this helps.
Dean
Mar 13, 2011 | Traeger Industries BBQ075 All-in-One Grill...
My trager does not get any hotter than 360. what is the problem?
The temperature limit could be from not enough air getting to the fire.
If you haven't already, clean out the fire box (it can accumulate unspent pellet debris) and especially the air holes around the base.
Jan 12, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Partially functional
Check for for conductivity. Wire may be fried.
Jul 24, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Traeger 075 tripping GFI continually
May be too much moisture on the hot rod.
From Traeger:
Jun 19, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Is the fuse a 2 amp or a 7 amp
They are a 3 amp fast blow fuse, and Radio Shack does carry them.
Mar 07, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Grilling Logo
289 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
