SOURCE: multi-coloured vertical lines on LCD screen and view finder
Hello, there is a chance for the Sony recall. Please contact your nearest Authorized Sony Service. If you need more info please advice.
SOURCE: TLM 2619 MODEL-DISPLAY PROBLEM
The most common cause for the loss of picture is a bad Horizontal Output Transistor
(HOT). but I would suggest you get a detailed
estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system
has failed. There are over 100 components in this section and any one
of them, or most of them can be at fault. However, the most common
failure is the VOT or vertical output transistor (which is often buried
inside a chip).
The repair will cost around $250 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding
that is fowling things up). Unplug the power cord; leave it disconnected
for 4 hours. That will restore everything to factory defaults when you
power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic
places to see if there are any cold solder joints or loose wires acting
up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair..
Goodluck..
SOURCE: vertical lines and distorted colour on display screen
Just as I got on line to this site I saw your problem being typed in and it's the exact same issue I am having with my Finepix 5000. I've owned it for all of 4 plus years with no problems and really decent photos. I'm getting a blurred image with green/magenta colors when I look through the viewfinder. When I take a photo, it shows the same. It wasn't dropped or even barely touched between the last good photo taken and this. Attached is an example of above description. I would appreciate any advise. See below.
SOURCE: westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
SOURCE: 29"Colour TV ,Sound Normal ,No Picture a vertical line Appears
Fault in HZ Deflection Stage check yoke also
