SOURCE: i have a lg lfx25960sb,it is showing ER IF code on
ER IF indicates that the ice maker fan is not working. The fan is probably frozen. Remove the fan duct and housing at the back of the freezer and you may be able to defrost the ice in the fan enclosure. It will not defrost sufficiently by turning the freezer off for 2 to 4 hours as LG suggests. The fan may have frozen because of high humidity or because the defrost cycle is not working. If your unit is still under warranty LG should fix it by replacing the fan, duct panel and control board with new ones that have been re-engineered to prevent this problem.
SOURCE: My Kenmore Elite 79577563600 is showing Er 1F.
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#@%
SOURCE: Kenmore Elite Refrigerator Trio display panel read
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
SOURCE: H20 dispenser displays er lf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
