Should be instructions down by motor I think motor error
SOURCE: kenmore elite 7.0 cu. ft HE4 GETTING A CODE E 2
The part number for your thermistor is 3976615, and can be obtained directly from Sears for about $30.
It is #42 on this parts list:
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00003&documentId=K0410034&modelNumber=11085861400&productCategoryId=0151200&brandId=0583&modelName=RESIDENTIAL+DRYER&backToLink=Return+to+Sub+Components
You may be able to find it cheaper from other sources.
If you want, I can look for other suppliers, just let me know.
Good luck.
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
SOURCE: What does the Ld code mean on a calypso Kenmore
Hello there
LD means a long drain
it is taking longer than 8 minutes to drain out the tub
please check the following
First unplug the machine to prevent electrical shock·
Check wiring harness to ensure they are all connected and are not fried
·If needed remove the side panel and Check the hoses going to pump for clogs and all drain hoses and drainage system
· Check circuit board that controls the pump to see if any wires are burnt or have failed
once the faulty part or the clog has been cleared simply plug in the machine and press the cancel button and resume your normal washing operation
Hope this has been very helpful for you
Best regards Michael
Testimonial: "Thanks for the feedback....the water pump had a sock.....Thanks...."
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
