Question about Equestrian
A horse with stifle issues in any pain - Equestrian
    New Friend:
  • 3 Answers
Re: Horse with stifle issue in any pain? Hopefully you have your answer by now. But in case you don't, yes - it is possible for stifle issues to result in pain. The stifle joint is equivalent to our knee. But the horse's knee cap is attached with 3 ligaments, not just one, like ours. In stifle lameness, the ligaments - or at least one ligament - is/are too long. As a result, the knee cap gets hooked over the end of the femur, above the stifle joint. This can cause the leg to remain stiffly extended behind the horse, or it may just catch-and-let-go-suddenly, causing potential damage to the joint, probably some bucking/kicking in an attempt to release the joint, and potentially also pain. One way to help a horse with minor stifle issues is to repeatedly back it up a slope. Don't over-do the exercise, but it will need to be repeated frequently enough to help the horse gain strength in the flank and gaskins. If the stifle lameness has progressed enough that the horse's normal movement is frequently halted, it may be possible for your veterinarian to quickly and easily solve the problem with stifle surgery. It is a simple procedure (fairly common in race horses) in which one of the ligaments is surgically sliced right through. The remaining ligaments can then apply their forces without the influence of the third ligament, allowing the kneecap to travel a different pathway - where it no longer gets caught on the end of the femur. Unfortunately this procedure is not always possible for very small ponies (such as mini horses) as the structure of the stifle joint may be too small and delicate. Good luck with your horse!
Posted on Dec 23, 2018
    Top Expert:
  • 34,129 Answers
Repair website or dont you know that>???
Posted on Sep 13, 2018
6ya staff
SOURCE:
Pain in the foot, ankle and calf
Hello, Kathleen -
If you would like to have an idea of what is causing your severe pain before you go to your primary physician and have your situation evaluated, I refer you to the well-respected health and medical website WebMD and its Symptom Checker:
https://symptoms.webmd.com/default.htm#introView
Please do not self-diagnose and make an appointment with your primary physician SOON!
Best wishes.
Feb 20, 2018 | The Health & Beauty
I have pain on right side down in the growning lowerback into my tail bone and a constant horseness
Nothing to do with cars and trucks unless your seat is uncomfortable.
Jun 04, 2017 | Cars & Trucks
I have a wheel horse 1973 10 8 speed and I need a wiring diagram
Do I understand correctly that you need the wiring diagram of a WHEEL HORSE? I don't want to be rude and delete this question MABBE YOU COULD EXPLAIN BETTER the issue
May 29, 2015 | Cars & Trucks
Make words with this letters. W f s t e f i p l o l i
Can't find any with all letters. Using only some
lowlife, lowliest, fifties, fillets, slip, lost, lie, oiliest, piffle, pillows, pilots, selloff, spill, stifle, still
May 30, 2014 | Games
What is the error code E2 for Magic Chef 2.1 cu. ft. Top Load Portable Washer?
I put this answer in the comments but re-posting here because I didn't know what I was doing : )
The Magic Chef 2.1 cu ft Portable washer manual says that its a door malfunction and the solution is to open and close the door. That did not work for me so if you're having the same issue that I am it may be that your washer is not level. I had placed mine on top of a few folded throw rugs to stifle noise (I live in an apt, on the second floor) and the rugs were uneven. As soon as i adjusted them, the washer began to work again. I hope this helps.
May 26, 2014 | Magic Chef Washing Machines
Does a rubber nosed hackamore hurt the horse/pony
If you are a competent rider then you know that hackamore's use resistance or reverse pressure. The horse cause's the pain or irritation by his movements. Always ride with soft hands. Heavy handed rider's can cause pain with hackamores.
Nov 29, 2013 | Horse.com Westen CP Rubber Covered Nose...
How often should I groom my horse?
You should be grooming your horse lightly every day. You should brush its hair, remove burs and make sure that it doesn't have any caked on mud. If you over groom your horse daily, you can accidentally take away some of the natural oils and minerals his body needs to stay healthy.
Jan 14, 2013 | Equestrian
I have a tl 1000 and ehen in first gear it jump back in to nutrul people tell me the dogs ars wor out do u now how I can fix them
this is a big job mate these are a pain to re time in and are a pain to strip, take engine out yourself, and fit yourself, let a mechanic do it for you. gear boxes are rocking horse dood dooo ould be a bent selector I thin also.
Mar 28, 2012 | 1999 Suzuki TL 1000 R
Equestrian Logo
202 people viewed this question
Top Equestrian Experts
Matthew Walter
Level 1 Expert
JOHN BROWN
Chris Walker
Chris Walker
Are you an Equestrian Expert? Answer questions, earn points and help others
