Question did you switch it on at the ignition switch
Testimonial: "Yes it did. I also notice where you adjust the choke when u put I think on stop it has that little kill switch thing. Well that switch has 3 male ends coming off but only 2 wires connect guessing that’s supposed to be that way but not sure"
SOURCE: my ryobi x430 will not start. Replace spark plug and still won't start
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, 11
SOURCE: RYOBI Expand It 2 stroke engine. RY26000 won't
I had the same issue. I disassembled carb and cleaned. Started up, but ran poorly. Looked at a few google searches and found a forum about his issue. I came across a write up about failed muffler bearings. I did some research, but to no avail. on part numbers. I went to a repair shop and inquired about how to get a muffler bearing ordered for my unit. It has been about a week since I was at the shop and I did call, but they assure me that they are working on getting this part for me. Apparently these motor parts are made in China and that can create some issues when trying to get parts. I may have to let the repair shop do the repair since I was told it may be a bit complicated to replace without having the experience. If it is as difficult to locate, I would not want to damage it when trying to install and have to get another. I will be glad to repost once it has been repaired. Perhaps this muffler bearing is an issue with a lot of other units and we may be able to contact the manufacturer for a refund or a free muffler bearing? I hope!!! Good luck out there and hang tight. I may be on to something here, I've got a good feeling about this.
SOURCE: Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
SOURCE: Craftsman generator, several years old,
pour a little raw fuel into carb intake. try to start. if engine runs for a few seconds and quits the problem is more than likely a clogged carb. go to auto store and get a gallon can of carb clreaner and dissassemble carb and lower into bucket and let soak over nite. you'll want to get a carb kit to replace any gaskets that may get messed up during tear down. when you go back together make sure to wash any residue of cleaner out of carb and use a small nozzel air blower on air hose to blow out ALL passages any needle valves have to screw into. take a can of carb cleaner and with the small straw place over hole and squirt into hole. make sure cleaner come out some where in carb body. that way you know all the passages are open. reassemble and crank her up.also invest in a compression guage. remove pllug and screw gauge into plug hole. pull sharply at least 5 times and see what the reading on the guage is. should be at least 70 or better. if rings and valves in good condition don't be surprised at a reading of 120 or better.
