SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
SOURCE: water pressure switch
if you can find the machines tech diagnostics sheet under the lid or inside the control panel try those diagnostics first,then,you should be able to blow air through the top tip of hose that connects to the water level switch and have air come out in the tub,if its clear as in easy to blow through,then replace the water level switch
